jandn73
Jul 13, 2007Explorer
Paul Turpin Jim, did you get it fixed? You should also check the power line coming into the Load Center that should be under the bathroom sink. Open up the 110 side and you should see the 10-2 Romex coming in from the power cord and the 10-2 Romex generator power cord. If they are not marked inside the box, remove the four corner screws and the complete box can be pulled partway out of the sink cabinet and check the 110 wires going into the box for markings. Check to see if you are getting power from the generator also check to see if you are getting a good connection on your generator wires. I had a bad connection on a 110 wire that had to occur after 2 years of driving down the road. Good luck and let us know how it worked out.
[/quote wrote:
Paul -
I pulled the electrical panel from under the sink and took a look at the automatic transfer switch attached to its back. I decided that there was not enough slack in allthe electrical cabling, I had no idea what I was doing electrically and that it was too hot in the coach without the A/C (shore power was disconnected) for me to continue further. I know my limitations, both electrical and comfortwise.
I started the genset and low and behold, I've got 120V power throughout the coach. Maybe I'm more skilled than I think I am.
I know that I'll probably have the same problem again but I'm going to wait until I can get some assistance in making the proper tests and /or repairs.
Thanks for your help!
Jim
Asheville, NC
38,769 PostsLatest Activity: Mar 29, 2026
