kormiadmin
Aug 15, 2007Explorer
Have had nothing but problems!! 2006 36D 8000 miles.
Trans went out at 3500 miles on HWY1,CA.
Slide outs (both leak and continue to leak).
Backup camera never has worked correctly.
Cabinets replaced from water damage (slide out leaks).
Cabinets replaced from water damage from skylights leaking (both).
I opened up the battery box and saw corrosion, when under the battery box and found duct tape holding up a metal bar, I cut the duct tape and the bar fell on the ground.
The passenger side dash vibrates so bad it cracked the trim molding.
The parking brake stays on unless you tap the dash or adjust the steering column.
Running lights shorting out.
Fleetwood has a list of 38 items that need to be repaired or replaced.
Just to name a few items...so I'm wondering if anyone out there is having the same problems?? Check under your battery boxes!!
email me if you have the same issues please.
Thank you.
kormiadmin@comcast.net
Thank you.
38,769 PostsLatest Activity: Mar 29, 2026
