MrMudstud
Aug 31, 2007Explorer
Phelangroovy,
Until you find the problem with your slide, may consider cutting a 2x4 to fit on top of the slide inside the cab to wedge it against the side to keep from it moving out during travel. If you use this procedure, don’t forget to remove it before activated the slide. Good Luck..........
38,769 PostsLatest Activity: Mar 29, 2026
