wa0mqe
Dec 08, 2007Explorer
Question for Rich & Cheri and and Fyr guy... I want to install the window awnings also. I researched it quite abit last summer but couldn't make up my mind which would work best, A&E or Carefree.
Also, I wasn't sure if I should go with one long awning over the two windows in the large slide or two separate ones due to the window height difference. Which way did you all go? I prefer the one long one if it will work. I was also a little concerned in getting too close to the slide out awnings rear bracket. Fleetwood mounted them alot further in then the needed to be, I think.
Also, both of you guys, do you have the exact model and size you installed? Did you go with the normal length or the longer length?
Questions, Questions, isn't it a kick.
38,771 PostsLatest Activity: Apr 15, 2026
