Fyr_guy
Dec 08, 2007Explorer
wa0mqe wrote:
Question for Rich & Cheri and and Fyr guy... I want to install the window awnings also. I researched it quite abit last summer but couldn't make up my mind which would work best, A&E or Carefree.
Also, I wasn't sure if I should go with one long awning over the two windows in the large slide or two separate ones due to the window height difference. Which way did you all go? I prefer the one long one if it will work. I was also a little concerned in getting too close to the slide out awnings rear bracket. Fleetwood mounted them alot further in then the needed to be, I think.
Also, both of you guys, do you have the exact model and size you installed? Did you go with the normal length or the longer length?
Questions, Questions, isn't it a kick.
I went with Carefree with the long awning over the slide and a single long with extended arms over the hallway windows. I also added one for the kitchen cause the boss wanted it for the early morning sun. We also matched the material on our main awning and they have the metal roller covers for when underway. Not sure of model numbers.
Sandy
38,771 PostsLatest Activity: Apr 18, 2026
