Paul_Turpin
Jan 22, 2008Explorer
Naval Aviator wrote:
Just bought a 2003 Pace Arrow 36B (3 slide). So far (with 750 miles under our belt) we love it. However, the automatic awning (Weather Pro) does not work. Previous owner said it worked fine on his last trip but when he arrived home and went to clean the awning, it would not extend. In fact, it apparently has no power to it at all. Nothing lights up at control box and the enable/disable switch makes no noise when enabling it (prior owner says it normally did make a small noise in the past).
Hoping this is just a blown fuse. However, I cannot find the 15A fuse for the awning. Does anyone know where a fuse might be besides the one in the control box (which looks OK)? Is there some other possible solution someone might know of?
Thanks
I am going to do some work on my P/A tomorrow and I will check for the fuse. There should be a fuse in the main fuse box that has the 110 circuit breakers and 12V fuses. My main fuse box is under the bathroom sink. If no one has an answer for you by tomorrow night I will post what I found.
38,778 PostsLatest Activity: Jun 07, 2026
