bricot
Feb 28, 2008Explorer
Meme&Ray wrote:
Thanks for the info. We have had that happen before too and never were able to get to the bottom of the problem.
MemeRich & Cheri' wrote:
Had an interesting experience. Twice now I've used my windshield wipers during a heavy rain and they wouldn't turn off afterwards. Had to disconnect the power under the frony cowling. The first time when I got home I reconnected the power the wipers were OK. This time I figured maybe water was getting into the connector. When I looked into the male end of the connector block I could see some greenish corrosion of the brass connection blades. I scraped it out and wiped out the area with alcohol on a Q-tip. Seems to have fixed the problem. If anyone has a similar problem, the connector is up under the down slope for the dash, just above the wiper drive motor. It is accessed from the ouside with the "hood" up.
Which side of the connector are you referring to, where it plugs into the wiper motor or the opposite side?
38,778 PostsLatest Activity: Jun 07, 2026
