Rich___Cheri_
May 23, 2008Explorer
glewis wrote:
Took lightning hit thru plug in oxford,Ms week ago. Took out plug, coffee pot,back tv,microwave(still checking),poped fuse on fridge(Found and fixed)I now have no charging system for my batteries. Is my converter in the fuse panel under the sink? Is there a fuse somewhere I can check?Charging batteries with plugin charger for now. also my generator is still putting out voltage but not converting to 12 volts hope it is same fuse or problem. In Jackson, Ms. on a job right now. Thanks GREG Email hgcjlewis@gmail.com
Converter is located under the washer/dryer. You can see it if you take out the grill at floor level unjder the hutch in galley area, (under fold-up table in center). The converter is very difficult to get to and probably requires removing washer/dryer and lifting w/d floor. Can also get to part of the converter by removing the propane detector, although this may be difficult. My detector was "cemented" in with foam insulation. I was checking my propane detector, not converter so I can't tell you any more.
38,778 PostsLatest Activity: Jun 07, 2026
