Paul_Turpin
May 25, 2008Explorer
glewis wrote:
Took lightning hit thru plug in oxford,Ms week ago. Took out plug, coffee pot,back tv,microwave(still checking),poped fuse on fridge(Found and fixed)I now have no charging system for my batteries. Is my converter in the fuse panel under the sink? Is there a fuse somewhere I can check?Charging batteries with plugin charger for now. also my generator is still putting out voltage but not converting to 12 volts hope it is same fuse or problem. In Jackson, Ms. on a job right now. Thanks GREG Email hgcjlewis@gmail.com
GREG, If your converter is under the washer/dryer like mine and you have to replace it, let us know how you had to do it. I looked at my converter and was wondering how hard it would be to replace and if you had to remove the washer/dryer.
Good luck
Paul
38,778 PostsLatest Activity: Jun 07, 2026
