Meme_Ray
Oct 20, 2008Explorer
We just came back from a short weekend trip and moved the baffle from the bottom vent to the top vent and our refrigerator stayed on gas for the 1.5 hour duration of the drive. Hopefully this is a trend. Thanks for your help.
Meme
Meme
Paul Turpin wrote:Meme&Ray wrote:Paul Turpin wrote:
Meme,
Thanks, I got the same thing from Dometic a few week ago but I didn't know it was called a baffle kit. Like you, I have not put it on yet but looks simple. What my refrigerator was doing is when I am driving down the Interstate 55+ and the wind was blowing in just the right direction on the side, the wind would go down the flew and blow out the flame. It would relight then get blown out over and over until the check light comes on. I am going to start puting the wind block on the the top refrigerator side vent to see if that stops the wind.
Paul & Sue:
I am hoping you see this message and can let me know if you did install the baffle kit on your P/A and whether you ended up with it installed on the top or bottom vents and if it worked for you? We are still having the problem but we installed the kit on the bottom vents with really no success. Hope to hear from you.
Meme
Hi all, I have been away from the WiFi. I put the baffle kit on the top vents. The wind was going into the top of the baffle then down the tube blowing out the flame. Unknown if this helped or not because I was wondering around a RV parts warehouse and found a L shape shield that cliped over the top of the baffle tube that let the fumes/heat out and blocked the wind from blowing in. It was used part setting on a old RV refrigerator on the ground. I only use it when I travel and I take it off when I stop for awhile.
38,778 PostsLatest Activity: Jun 06, 2026
