Paul_Turpin
Mar 02, 2009Explorer
Mel,
The city water valve needs replacing. There is a check valve inside that is bad or stuck. If you remove the three screws on the valve, it should pull out so you can disconnect the water line. There are several city water fill valve so take the old valve to match it. It is easy to do and don't cost much, so I would replace it than try to fix it.
Paul
Paul
Cathy Johansen wrote:
Problem:
When I use the water pump in my 2004 Pace Arrow, water comes spewing out of the city water fill valve.
Is there a stuck valve somewhere in the system?
Mel
38,778 PostsLatest Activity: Jun 06, 2026
