Meme_Ray
May 05, 2009Explorer
NOTICE OF WORKHORSE RECALL ------------------
In the past year we have had this problem with all 4 of our disc brakes on our 2004 37C Pace Arrow. I talked with Workhorse earlier this week and was told that notices would be going out in June to effected vehicle owners. If you have had repairs already made you should still be able to file for reimbursement but need to contact Workhorse for a reimbursement form. There is a number towards the bottom of this e-mail. Be sure to have your VIN# available or be prepared for the Customer Service rep to hassle you a bit. WH should still be able to search for your vehicle if you tell them the name it is registered under. You will also need proof of repair and proof of payment. Just a copy of the bill from the repair facility is not enough.
If you notice that you have fluid steaks on any of your tires or some odd stains you are probably having this problem and may not be aware of it. It was a little unnerving when our breaks went out in the Smokey Mountains last month and frustrating when we had to pay to have our breaks repaired for a 3rd time.
Hope this helps some of you.
Meme
Make: WORKHORSE Model: W22
Model Year: 2004
Manufacturer: NAVISTAR, INC Mfr's Report Date: APR 01, 2009
NHTSA CAMPAIGN ID Number: 09V110000
EA07016
NHTSA Action Number: EA07016
Component: SERVICE BRAKES, HYDRAULIC
Potential Number of Units Affected: 47042
Summary:
NAVISTAR IS RECALLING 47,042 MY 2001-2008 WORKHORSE W20, W21 AND W22 SERIES RECREATIONAL VEHICLES EQUIPPED WITH AXLES THAT INCLUDE BOSCH ZOPS OR ZOHT PIN SLIDE HYDRAULIC DISC BRAKES. WHEN COMBINED WITH OCCASIONAL OR SEASONAL VEHICLE OPERATION MAY EXPERIENCE CALIPERS STICKING IN THE APPLIED POSITION. THIS CAN RESULT IN ABNORMAL HEAT GENERATION AT THE WHEEL END CAUSING BRAKE DRAG. THE DRIVER WOULD NORMALLY HAVE WARNING OF THE BRAKE DRAG IF UNDETECTED BY THE DRIVER.
Consequence:
THE TEMPERATURE INCREASE AT THE WHEEL END CAN EVENTUALLY LEAD TO SOFT PEDAL CONDITIONS DUE TO BRAKE FLUID BOIL, AND POSSIBLE EXTENDED STOPPING DISTANCE INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE NECESSARY COMPONENTS FREE OF CHARGE. A REMEDY IS CURRENTLY NOT AVAILABLE. OWNERS WILL BE NOTIFIED BY MAIL WHEN PARTS ARE AVAILABLE. OWNERS MAY CONTACT WORKHORSE AT 877-246-7731.
Notes:
WORKHORSE RECALL NO. 50901-C. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Meme
Model Year: 2004
EA07016
Summary:
Consequence:
Remedy:
Notes:
38,778 PostsLatest Activity: Jun 06, 2026
