dkingdoe
May 11, 2009Explorer
seatec wrote:
Question,
Have the KIB C07 monitoring panel. Strange thing happend. i pressed the frsh water tank button and the led briefly lit up and then went out. now none of the water indicator LED's or the battery level display work. everything else on the panel like the slide and water pump buttons work. Just not the indicator lights or display. I checked all fuses under bathroom simch and in fuse compartment next to door steps but cant find a blown fuse. Anybody have an idea what this could be? I also didnt see an inline fuse anywhere when i pulled the panel to look behind it and the plug is firmly seated.
Thank you
dkingdoe wrote:
We had this problem back I few years ago. I'll go look thru our repair records to see what the solution was and post what I find.
--dk
Seatec >> I went and looked thru our repair records and the solution was...the fuse for the monitor panel is a shared fuse with the CO2 detector + monitor panel. That fuse is located in the fuse compartment next to door steps. Check the fuse marked 'CO2' to see if it's blown. I know it sounds crazy but that was our problem.
Hope this helps.
~~ dk
38,778 PostsLatest Activity: Jun 05, 2026
