Meme_Ray
May 11, 2009Explorer
Dennis:
The Dometic Air Foil Kit is #3108039.003. We only installed the vent baffles on the upper refrigerator vent. We did not install the burner shield.
We also have had a problem with the propane alarm going off you describe. I check our service records and found that the dealer replaced a bad electrode 2932781020 in the refrigerator.
Hope this helps you.
Meme?
Meme?
Dennis37 wrote:Meme&Ray wrote:
Refrigerator problems while driving finally solved.
Well after 5 seasons of driving I am happy to report we can finally drive down the road with the refrigerator on gas and not have it continually go out on our 37C. The Dometic air foil kit we installed on the top outside vent (not the bottom vent that we previously tried) has finally fixed the problem. We installed the air foil kit parts in the forward most position and have had 3 successful trips with the refrigerator running.
Meme & Ray,
Do you have a link or part number for the kit?
My propane alarm goes off while driving (never while parked) if I have the frig on propane.
I have had the system checked for leaks none found.
Thanks in advance for you help.
38,778 PostsLatest Activity: Jun 05, 2026
