Fyr_guy
Jun 02, 2009Explorer
Jim Bakker wrote:bricot wrote:
Had a bolt shear off of one of our big slides last weekend when trying to pull it in.
What happened to indicate a problem? Were you able to retract the slide or did it get stuck in an extended position? Inquiring minds want to know all the details!
On mine, I noticed the living room was not coming in evenly, went outside to take a look under the slide, noticed the broken pin on the ground. I actually was able to turn the long metal bar by hand to return the slide to the out position. I then came inside to do the research on Power Gears site and it explained how to "Unlock" and unplug the motor from the bar in order to replace the shear pin. Hope this helps.
38,778 PostsLatest Activity: Jun 05, 2026
