bricot
Jun 02, 2009Explorer
FreshAir wrote:
Fyr or Bricot, when one calls Power Gear for a shear bolt how do you refference or describe the bolt you need? I think a spare might be the way to go.
Pat
Its the nut/bolt on either side of the drive 'shaft' or 'bar' for the slide. On one end it attaches the drive 'shaft' to the drive motor, on the other end (gear side) it is the bolt right before the large cotter pin. These are the only two bolts that go through the drive 'shaft'. The shaft consists of 2 square metal metal bars that slide inside of each other to adjust for length.
38,778 PostsLatest Activity: Jun 05, 2026
