bricot
Jul 13, 2009Explorer
Fyr guy wrote:
On the 37C we have 2 arms to control the living room slide. The bolts attach the square tubular metal bar to the motor mounted in the middle and turns to push in/out the slide. In visiting the powergearus.com site, it no longer has schematics to show the part number.
Exactly the metal drive bar bolts to the connector on the gear mechanism, which has a cotter pin release in case you need to manually pull the slide in. I've got the local place looking for part numbers and to see if the bars are universal between my two larger slides. Each side of the drive bar has an inner and outer piece that slide in/out to create the correct length.
38,778 PostsLatest Activity: Jun 04, 2026
