rolnhome
Aug 02, 2009Explorer
On the inside outer door is a plactic "catch". It is spring loaded so that when the doors are closed together it graps the screen door latch and pushes the button so the screen door will not latch. This allows the two doors to open and close as one unit. The only way I know to operate them seperate is to manually release the "catch" holding the two doors together each time you open the outer door, this can only be done from the inside of the coach if the doors are closed. You do this by lifting up on the "catch" to release the screen door. The "catch" is shaped like a sideways V. Working properly booth doors open when opened from the outside of the coach.
Hope this helps.
Hope this helps.
38,778 PostsLatest Activity: Jun 04, 2026
