init6
Oct 13, 2009Explorer
Lobstah wrote:
Thanks to all for the numerous replies. Many of you have different floor plans, and so the info definitely does not apply, however...that being said, here's Part 2 of the saga, and how things developed once we got to our campsite.
I plugged into 30A power, and had the same symptoms I had at home on my 15A circuit from the garage. In the process of getting set up, my wife decided to vaccuum the living area, and plugged the vaccuum into the outlet along the kitchen counter...dead. No power at all. Microwave is working, hot water is working, but no power to that outlet. So I move to the plug under the dinette, presto, power. Then one of our friends wanted to vaccuum their tent, to we gave them the vaccuum, and I told them to use the plug in my belly-box...dead. So NOW it occurs to me that the outlets that don't work must be on a GFI breaker, but I have no GFI breakers on my breaker panel. This means that the GFI is on an outlet somewhere, and it's always either in the kitche or in the bathroom. Turned out to be in the bathroom, behind a towel hanging on a towel ring. As soon as I pushed the reset, everything worked, including the inverter/charger and the frige.
SO...
The problem was the forklift running over the extension cord in my driveway, which not only popped the GFI breaker in the garage, but ALSO popped the GFI breaker out in the coach. And even though the frige had 30A of AC power, it still needs DC voltage from the batteries in order to work.
Also, as for location, the converter/charger location is down to 2 places. One is in the passenger's belly-box, right above the propane tank, the other is in the panel under the glass cabinet. I haven't looked there yet, but will open things up this coming week.
The box that someone mentioned being under the bottom large drawer in the kitchen is actually one of the two furnaces on a 36D.
Thanks to everyone for the help and encouragement!...and go find your GFI...you never know when you're going to need to reset it ;)
Jim
My next guess would have been a blown Flux Capacitor !
Glad you got it figured out.
38,778 PostsLatest Activity: Jun 03, 2026
