bricot
Dec 29, 2009Explorer
Paul Turpin wrote:
Has anyone remove the door entry handle assenbly?
The gasket that goes between the outside door and the door handle assembly fell apart/then tore off. I tighten the handle assembly but without that gasket the handle assembly continues to slides out of adjustment when driving down the road. I started to remove the screws but not sure what I am getting into, I put it back together.
Can I remove the door handle assembly, replace the gasket, then replace the handle assembly without parts falling inside the door?
I've thought about doing the same just to clean it up (door closes hard and screen catches periodically when opening), let me know if you get brave :)
Well the cold weather took out my water pump and both filters. Anyone had any problems with the ShurFlo 5.7 Extreme with 'smart sensor'?
Pretty spotty reviews across the net, but I needed a pump. With a 3 year warranty I figure I can replace with the mechanical (if they come out with it this summer as rumored).
38,778 PostsLatest Activity: Jun 03, 2026
