Paul_Turpin
Feb 25, 2012Explorer
Eddie
I got to ask, how did you get a P/A in Ireland?
I had the same problem under warranty (years ago) and I was told they do not work on them and ordered me a new motor. If the motor still works you can do what I had to do until I got the new motor. I made two bars from water pipe that can be screwed out to fit tight between the inside wall and slide out. I would lay the pipe on top of the slide out on heavy rags so they would not damage the slide out also so it would not come loose, roll off the top of the slide out and hit someone as you are driving down the road. If you are going to do this for a long time, they sell the slide out bars. I just had the water pipe laying around and it was only two week wait for a new motor.
Good luck
Good luck
38,780 PostsLatest Activity: Aug 05, 2026
