Jachinator
Apr 13, 2012Explorer
Sawellman, I have fixed two Pace Arrows that had the same problem. First you have to locate the tech screws that they use to secure the dash. Sometimes they are buried under black chalking. The screws more than likely have worked themselves out and are missing or stripped out. The holes should be on the black angle iron that is mounted to the dash, very left corner, about 1 inch wide. You have to find one of the holes to see if you are lined up correctly before you reinstall with bigger tech screws, not longer(could puncture the outside of your RV. I also drill about 6-8 more holes and insert more screws into the angle iron and the wall of the coach. This has fixed the problem on two of my pace arrows(2004 & 2006). I hope this helps, sorry I don't have any pics. If I get a chance I will take some and post.
38,780 PostsLatest Activity: Aug 05, 2026
