FreshAir
Apr 14, 2012Explorer
Seems like someone once posted a pic of the location?? I couldn't find it.
Best position to see the black 1" angle iron that is welded to 1" square tubing is on the drivers side as there are less cable bundles obstructing your view.
The angle iron, which has the small undersized screws, runs vertical and is spot welded to the square tubing also running vertical against the firewall. The angle iron is attached by the screws to fiberglass body.
On my Pace, when I lift the hood I can put my thumb on the side of the hood opening and with my fingers extended,reach in at about a 45 degree angle towards the side of the coach and touch the angle iron were talking about. Same thing on passengers side.
I replaced orig. screws, some were missing, with much larger, I think 1/4" hex head screws. Can't remember length. I also drilled and added more. Like said before, be careful on length as you don't want to screw thru fiberglass side.
Jim, I don't know how you would jack up the body to fix this. Maybe the whole thing is at rest where it should be and the stress is greately reduced now. If everything looks OK and seems aligned alright, it might be best to secure it where it rests now with larger screws?
38,780 PostsLatest Activity: Aug 05, 2026
