FreshAir
Jun 05, 2012Explorer
seatec wrote:
THanks PAceArrow. THats the 55amp one. I have a 75 amp one so i'd have to get the 9875. thanks for all the input guys.
Why do you think you have to have the 75 amp one? I had the same converter you had, a WFCO 75 amp wasn't it? I replaced mine with the Progressive Dynamics 9270 amp. I'm sure a 55 would have been more than I'd ever need. Figure if you turned on every 12volt thing in your motorhome plus charging some batteries that happen to be low and running a decent sized inverter I think off hand, you'ld be hard pressed to require more than 55amps worst case scenario. I might be missing something but this was my quick estimate when I selected the PD70. As I recall there was a big jump in physical size and cost when going above the PD70 with Progressive Dynamics.
Pace Arrow just put the big ones in there because that's what they do. If your Pace is equipped standard as my 36 ft is, you'll never need a 70 or 75 amp. But,I could be wrong!
Pat
38,780 PostsLatest Activity: Aug 05, 2026
