Lobstah
Jun 25, 2012Explorer
There is a circuit in the Batt Control Center that enables charging the chassis battery depending on voltage available. Mine blew that fuse. I forget what the number was, it was a 3A fuse, and as you open the cover on the BCC, it was on the right side, down towards the bottom. I'd check the fuse(s) first. If you have 13.5 on the house batts, then that circuit is likely the problem.
Jim
Jim
38,780 PostsLatest Activity: Aug 05, 2026
