FreshAir
Oct 26, 2012Explorer
I have a 2005 36B and have on occasion my main slide would not go out or come in. In my case it was the ctl. relay for that slide. I could tap on it and it would work. Reseated it a few times and no more problems.
If all three of your slides are not working then I suspect your not getting voltage thru the Slide controller box. You have a relay for each slide. If you have a meter, that's the first thing I would check. Should be pretty straight forward as I recall there is a good diagram on inside of the box cover.
Let us know if you don't know where the control box is located.
Pat
ps; you know, if the park brake is not on, the slides won't work. Just a thought as I have forgot about it before.
Pat
38,780 PostsLatest Activity: Aug 05, 2026
