Lobstah
Dec 09, 2012Explorer
FreshAir wrote:
Lobstah, I have had my handle light burn out butI don't think it had any effect on the porch lite. Pretty sure.
I was buying my lenses for the porch lite from Fleetwood but had to buy the complete lite assembly, about $9 as I recall. Bought 5 of them as the diver side coach lite took the same part. I now would probably buy the complete LED asy. that some are now using.
Pat
The LED assemblies is what I installed. I don't believe that the handle light and the porch light burned out at the same time...I'm fairly certain that I have a problem with that circuit, I just don't know what fuse it's on. Won't be using the camper for the next 2-3wks, so won't be able to poke around the fuse panel with a test light until then.
I thought maybe someone had had to replace that fuse already.
Btw, the LED lights are much better than the orange glows that were originally on the rigs, and were VERY easy to install. Their base is bigger than the old light, so it covers everything up nicely. Just put a good bead of sealant on the new light, and make sure you carefully clean all of the old stuff off before you put the new one on.
Jim
