Lobstah
Jan 19, 2013Explorer
kuzined wrote:
Have a 05 37c. Pace Arrow. Cant get front drivers side leveler to go up or down. They are electric Atwood model. Use a drill to operate it.......but the pain is that I cant get rid of the error on the panel. Have to manually raise and lower the other three legs using the buttons. Third time this happened. Before, I went under and wiggled the wires and it started to work. Ground seems good, Now, there is no response. Any ideas?
Sometimes just moving the manual retract nut on the bottom of the gear drive is enough to clear it up.
You can also reset the controller...forget the procedure, but it's available online if you don't have the documentation. At one point, I had to replace a jack because it blew a gear. Other than that, it's usually an electrical/controller problem.
All of the connections come into your controller which on my 36D is located on the drivers side under the dash. The wires are connected to the board on the side that sits up against the wall, and are notorius for corosion due to condensation running down the wall and onto the controller, particularly those connections. Get in there with a flash light and maybe mirror, and inspect the connections and make sure they're ok.
Jim
