Fyr_guy
Dec 31, 2016Explorer
outofplace wrote:
I will be interested to find out how you access the mechanism as my bedroom slide creeps back in after you extend it against the exterior .... once you let off switch the slides comes back in just a tad
SUCCESS!! I ended up using a small pry bar to lift up the excessively stapled carpet off the plywood and found 1 screw at the foot of the bed in the center (under the carpet). I lubed (silicon) all the plastic wheels, teeth on track and anything I thought would produce a squeak. This cured my problem! The plywood board bends up enough to get to all the important lube points. I replaced the solitary wood screw with a cabinet handle backed by a small washers so I can access this mechanism in the future. Better to have done this at home instead of an emergency on the road. Thanks again for your suggestions.
38,782 PostsLatest Activity: Sep 10, 2026
