- R2DillonExplorerOn the 50 amp service, I was not aware that the 2004 had a 50 amp service model.
On the glare, I used smoke lexan, a hinge and rubber suction cups to make a movable screen to block the light from the front window. It removed the glare on the side windows. There was some discussion of fixes on the IRV website. - LobstahExplorerDoes anyone else have trouble with the two trays on the passenger's side of the dash opening up on bumpy roads?...in the Northeast, particularly in Mass, every single bridge seam will bang the heck out of anything riding over it, and my trays ALWAYS open up on rough roads. Tried looking inside to see if there was a way to tighten the detent to hold them closed, didn't see anyting.
Seems kinda wrong to have to put a piece of duct tape on the edge of the drawers as part of the checklist ;)
Jim - LobstahExplorerYes, the reflections can be bad on occasion, especially at night, I find. I wonder if some anti-glare film would help. That's the problem with straight glass for windows.
Jim - sawellmanExplorerHas anyone else experienced significant glare/reflection in the side windows adjacent to the rear view mirrors? When looking out the windows to see the rear view mirrors the glare and reflections are so bad I almost cant see my rear view mirrors. It is really wierd, almost like a mirror reflection of anything next to me. Has anyone else experienced this and found a way to fix it?
Suggestion fot anyone with humming sound: I have only been drivin my coach a couple of times but originally noticed this humming noise coming from the front. I found out that it was the grill catching air while going down the road. I plugged the ends with some silicone and that made a significant improvement. - wa0mqeExplorerI too have the Ultrapower. It has not helped my mileage at all. If anything the mileage is less then it was before Ultrapower. However, the is a definite difference in power from before. It doesn't shift down nearly as often as it did. I can run up a grade much longer and in many cases over the top of some moderate hills without downshifting.
A reminder on my question above about electrical schematics. Any comments, please? QUOTE: "Does anyone have any schematics for their 2004/05 36B/37C which is 50-Amp service? Mostly I'm interested in something showing the AC Distribution (Breaker Panel) and also the Transfer Switch." - FrontRangeRVerExplorer
sawellman wrote:
Seperate point on UltraPower upgrade: I have read all of the posts and am considering this for mine. For those of you that have had the upgrade for over a year now are you still happy with it, did you see any additional strain or wear on the coach/engine/transmission? For those of you with it in California - what is the deal with the upgrade relative to CA emission standards...does it still qualify for SMOG?
Took us a year to get a refund on our Ultrapower....glad to have our engine back to stock!!!!
And if the Ultrapower gets you 2-3 mpg increase....I have some swamp land in Colorado for sale. - bricotExplorer
Fyr guy wrote:
As for Ultrapower, I've had mine for 30K miles and it remains the best improvement I've had done on the rig. Climbed the Grapevine 2 weeks ago, with toad, and climbed it at 50-55 the whole way. You'll notice the power as soon as you drive off the lot. The MPG increase has been on the 2-3 range. Can't speak to the smog yet but I'm sure if you call and talk to Keith at Redlands Truck Center, he can advise/explain.
+1 - Fyr_guyExplorer
As for Ultrapower, I've had mine for 30K miles and it remains the best improvement I've had done on the rig. Climbed the Grapevine 2 weeks ago, with toad, and climbed it at 50-55 the whole way. You'll notice the power as soon as you drive off the lot. The MPG increase has been on the 2-3 range. Can't speak to the smog yet but I'm sure if you call and talk to Keith at Redlands Truck Center, he can advise/explain. - sawellmanExplorerOn the Power Gear jacks: I took my RV into my mechanic and while it was there discussed my experience with my jacks. They informed me that the jacks are in fact too small for the weight of the coach (only rated for 5,000lbs ea). So, when trying to level side to side (which is done by only one jack...left rear or right rear respectively) the jacks do not have enough power to lift the RV more than a little bit. Seems like the Power Gear jacks on the 2004 PA are more for stabalizing and not leveling. Frustrating as most camping I do is not on level ground. If anyone has any solutions or if anyone has replaced/upgraded their jacks on a 2004 PA I would love to hear what you did and/or your experience.
Seperate point on UltraPower upgrade: I have read all of the posts and am considering this for mine. For those of you that have had the upgrade for over a year now are you still happy with it, did you see any additional strain or wear on the coach/engine/transmission? For those of you with it in California - what is the deal with the upgrade relative to CA emission standards...does it still qualify for SMOG? - wa0mqeExplorerI was also reading the posts on the Power Gear jacks. I agree with the analogy that the jacks are not correct for this coach. The jacks are too small for the distance they must lift the coach to level it. They are also not big enough (pistons not large enough in diameter) for these coaches. As mentioned they are usually all the way out when getting close to leveling and this makes them wobble because the piston is extended so far, (hence the jacks being to small).
Someone mentioned the rear jacks lifting first. This is not what the instruction manual, nor Power Gear says. The two front jacks are supposed to lift first. They raise just a little, 1 or 2 inches, and then stop. The rear then will raise. The two front jacks operate as one jack. They are connected to each other with a hydraulic hose that allows them to work together. The left and right jacks on the rear are the ones that level the coach side to side. The front jacks will release pressure on the side that needs to drop and send the fluid over to the opposite front jack. If you look at the jacks you will see this extra hose that interconnects between the two front jacks. The rear jacks do not have this hose.
38,766 PostsLatest Activity: Jan 10, 2026
