- Fyr_guyExplorer
Jim Bakker wrote:
Has anyone replaced the under-cabinet halogen bulbs with LEDs? Did you have to remove the reflector? If so, how? My reflector is a bulky piece of pot metal so the tabs that clip into the plastic housing cannot be flexed. If you have been able to remove this type of reflector, please tell me how to do it. Thanks!
Jim, I replaced all my indoor halogens with LEDs. The replacements do protrude a bit so the reflector will not seat flush against the wood but for me the trade off was acceptable. I just left the existing reflector in place. Hope this helps. - Jim_BakkerExplorerHas anyone replaced the under-cabinet halogen bulbs with LEDs? Did you have to remove the reflector? If so, how? My reflector is a bulky piece of pot metal so the tabs that clip into the plastic housing cannot be flexed. If you have been able to remove this type of reflector, please tell me how to do it. Thanks!
- Jim_BakkerExplorerSubject: where can I get this part?
The cover on the Battery Control Center under the hood of my 2004 PA is held with a couple of lever-type clips. I've lost one. Does anyone know where I can purchase a replacement? I've been unable to reach RV Custom Parts (maker of the BCC). - MrMudstudExplorer
Paul Turpin wrote:
UPDATErichardc4 wrote:
I have a 35g, the bedroom would come in fine. When we went to extend the slide out it would start and stop or more like it would hit a snag and go again. I took it to CW and the slide was ok, it was the topper, it had become bent some how. New topper took care of problem.
I will admit I thought they were BS ing me. Not so.
Thanks, I checked the sideout topper and found that it WAS the topper. The arm was loose that the anti-billow arm was connected to and as the slideout was going out the anti-billow arm was hitting the topper bar. I fixed the topper arm and all is good. Thanks for that info it saved me a lot of time getting into the slideout gears and motor looking for the problem.
Mine did the same a few years ago, and since then I always check both my anti-billow arms occasional to be sure it doesn't happened again. With time the topper will stretch and the angle of the arm will change and my hit again. Just something to keep an eye on when making a walk around the coach. Glad it was a simple fix for you. - Paul_TurpinExplorerUPDATE
Thanks, I checked the sideout topper and found that it WAS the topper. The arm was loose that the anti-billow arm was connected to and as the slideout was going out the anti-billow arm was hitting the topper bar. I fixed the topper arm and all is good. Thanks for that info it saved me a lot of time getting into the slideout gears and motor looking for the problem. - dcbrewerExplorerI have a Pace 36D, both of the disconnect switches quit working. the ones for the house and coach batteries, they will not cut off power, and they do not click when switched. is there one fuse for both???
Thanks H.B. - Paul_TurpinExplorer
Good tip, I will check that tomorrow - richardc4ExplorerI have a 35g, the bedroom would come in fine. When we went to
I will admit I thought they were BS ing me. Not so. - Paul_TurpinExplorer
FreshAir wrote:
I have the 2005 36B. I lift the bottom end of the bed, pivots up to access storage, then remove all my junk, I then lift up the end of the thin slab of plywood that my stuff was sitting on, I don't remove it. I now have access to the motor and slide assembly. I don'tneed to remove any carpet Hopefully a lube job will fix it.
Pat
Thanks , I will get to it tomorrow.
Paul - FreshAirExplorerI have the 2005 36B. I lift the bottom end of the bed, pivots up to access storage, then remove all my junk, I then lift up the end of the thin slab of plywood that my stuff was sitting on, I don't remove it. I now have access to the motor and slide assembly. I don'tneed to remove any carpet Hopefully a lube job will fix it.
Pat
38,767 PostsLatest Activity: Sep 19, 2016
