- ParrotguyExplorerRe: Converter box
I have a 36D and all the electrical is either under the bathroom sink or under the glass enclosed cabinet to the right of the stove. Just remove the panel. The three switches are in from generator, in from shore power and out to coach. The problem as you have described it makes no sense to me, especially the fridge. It almost sounds like a battery cell has shorted out. Good luck. If you narrow it down let us know. I assume you tried a new extension cord. I'm guessing the extension cord has nothing to do with it. If the cord got flattened and the wires touched, the circuit breaker in the house would have blown and the coach would not be affected. - unionmanExplorerYou are right, I should have said along side of the sink behind the drawers.
- dkingdoeExplorer
unionman wrote:
I dont know off hand what floor plan the 36D is but I have a 36B & mine is behind the fuse pannel under the bathroom sink.
I, too, have the 36B floorplan, but mines located under one of the bottom drawers under the waderobe. Pull drawers out as far as possible and look under them. If all else fails, contact Fleetwood with your FIN & VIN #'s.
This is from their website:
Best method of inquiry for Customer Services:
Our call center is open 5 days a week to serve you. Hours: M-F 8:00am-5:00pm ET.
Call 800-322-8216. - LobstahExplorerThanks, unionman...I'll check there first thing this morning.
Jim - unionmanExplorerI dont know off hand what floor plan the 36D is but I have a 36B & mine is behind the fuse pannel under the bathroom sink.
- LobstahExplorerI'm posting this here due to the concentration of Pace Arrow owners, in hopes that someone can help with this problem. If it belongs in a different forum, please move it there :)
I have a 2005, 36D. It's been parked in my driveway for about a month, while we've been lining up our next trip. The coach has been plugged into a 15amp circuit to just keep the fridge cold, and run any lights we need should we go out to grab something from the coach.
Last weekend, Lowes delivered a load of patio stone to me, and ran over the extension cord going to the coach with their forklift. I didn't think anything of it when I discovered it, but tonight I went to start loading the coach and my house batteries are dead. Even though I have both replaced and reconnected my extension cord...the coach isn't getting 12V power. There is AC coming in to the coach, because the microwave lights up...and I can turn on the DVD/Stereo system, but my fridge won't stay running. If I start the coach, everything is fine, the fridge comes on, and my house batts get charged, but as soon as I turn the coach off, the batts start draining. I'm surprised that this impacts the fridge running on AC, but it apparently needs DC voltage to accomplish this :)
I believe I've blown a fuse in the inverter/charger, or possibly blown the unit itself. My problem is...I CAN'T FIND IT!!! lol
I've been through every cabinet, I have the manual on it, I've been through every storage compartment... I know the darned thing is right under my nose, but I just can't find it.
Sooooooooooooo...I pulled everything back out of the fridge, and Momma's giving my that look that says "If this doesn't get fixed, I'm not going ANY where..." :)
So if someone can point me to the physical location, I'd be grateful...
Thanks in advance ;)
Jim - Meme_RayExplorerJust in case you missed it, here is the recall information for those of us effected by the break recall. I would urge anyone that has not experienced a problem yet to still have an inspection done to make sure your brakes are really OK. We have had this problem several times and had all our breaks serviced at one time or another in the past few years and have even had repeat problems on repaired breaks. Thank goodness we never had problems will all breaks at the same time. If you notice any fluid marks on your tires you have probably had an excessive problem. Hopefully we can all get serviced over the winter months. Our dealer has told us that even though our breaks have been fixed in the past we will still need to have further service under the recall with the new replacement parts.
Good luck.
Meme
Fleetwood is recalling 509 MY 2001-2008 Class A motor homes equipped with axles that include BOSCH ZOPS or ZOHT pin slide hydraulic disc brakes. When combined with occasional or seasonal vehicle operation may experience calipers sticking in the applied position. This can result in abnormal heat generation at the wheel end causing brake drag. The driver would normally have warning of the brake drag if undetected by the driver. The driver would normally detect the brake drag but if undetected the temperature increase at the wheel end can eventually lead to soft pedal conditions due to brake fluid boil, and possible extended stopping distance increasing the risk of a crash. Dealers will inspect and replace the necessary components free of charge. Workhorse is handling the remedy for this campaign. The manufacturer has not yet provided an owner notification schedule. Owners may contact Workhorse at 1-877-246-7731. Workhorse will conduct te owner and dealer notification. - dkingdoeExplorer
Parrotguy wrote:
Parts: screen door
The L shaped small plastic part that holds the screen door to the outside door has broken - anyone found this part?
Thanks, Gary
Ours broke a few months back and I went to the dealer - parts dept. and they had one in stock...$6.54 (including tax). - ParrotguyExplorerParts: screen door & slide out topper.
Also the middle support to the large slide out topper has lost one of the rollers - the shorter one, 5" , as the axle cap fell off. Anyone found this part?
Thanks, Gary - dkingdoeExplorer
Meme&Ray wrote:
We are getting ready to head out to our favorite yearly trip to the Kentucky Bourbon Festival in Bardstown, KY. Lots of activities to take part in. Here's the link if you want to check it out.
http://www.kybourbonfestival.com/
Meme
38,778 PostsLatest Activity: Jun 03, 2026
