Hank85713
Aug 31, 2020Explorer
when I had my TT I wanted a place to haul my generator. I got 2 of the bumper bolt on receivers and about 6 ft of 2inch tubing. Bolted the receiver to the frame and then bolted the tubes thru the bumper/sewer hose carrier to the tubes Was very solid. You could do same thing and bolt to the receiver hitch for the secondary bolts. Run some tube down to the 2 inch tubing and weld/bolt together rather then try and bolt to unknown strength material in a wall. Remember that they are using LIGHT materials in walls and the walls are generally luan wood covered with a layer of fiberglass!
