Mr_Mark1
Feb 15, 2015Explorer
GlennLever wrote:
In my opinion you cannot bet the quality of an "older" high end Motor Home.
Parts are a little harder to come by but there are a number of salvage yards.
The point though is the parts used in the high end coaches last and you are not repairing them as often as the newer cheaper built motor homes.
Here is an example of a Prevost http://www.rvtrader.com/listing/1988-Prevost-Country-Coach-Mirage-113921482
The older Prevosts are usually rock solid, certainly the bus frame is. The Prevost pictured was converted by Country Coach who are now out of business. The good thing is that the chassis company "Prevostcar" is still strong and healthy.
The coach pictured is a fairly rare 40 ft. as most are 45 ft. For those that would consider this coach, maintenance records are paramount. If not, then it would be a good idea to 'zero-out-the-coach' for it to be fresh.
That includes changing of the norgren air valves, air bags, new hoses, oil change and filters, etc. which will run about $30,000. If the engine checks out, that would be a super good deal for a rock solid coach.
The plus in many people's eyes would be that it would be 'low tech'. The electronics today are mind boggling.
MM.
38,769 PostsLatest Activity: Mar 31, 2026
