Pangaea_Ron's avatar
Pangaea_Ron
Loose Fender Panel - Adhesive for attachment?
I have a 2008 Itasca SunCrusier 35L. The driver's side lower front fiberglass corner panel is coming loose. It is (was) attached with a thick black adhesive to perforated metal angles attached to the frame. The adhesive on the back of the panel was meant to ooze through the perforations in the angle and hold the panel in place. The adhesive seems well adhered to the metal angles, but the portions of the adhesive that penetrated the angle on the fiberglass panel has torn/separated.
What is the adhesive material? Can I use Gorilla Glue?
