Has any one heard of the Cummins 8.3 ISC having a loose injector causing combustion products to enter the return fuel going back to the main tank and causing the fuel to turn black, then clogging filt...
Never heard of a loose injector causing this kind of problem but it almost makes sense. You would assume the carbon is entering the tank through the fuel return line and possibly some blow-by at the injector could cause such a thing. Keep us posted as to what you eventually find. Have you considered installing a fuel filter on the fuel return line?
