Tom_BarbExplorerDec 18, 2015Loose InjectorHas any one heard of the Cummins 8.3 ISC having a loose injector causing combustion products to enter the return fuel going back to the main tank and causing the fuel to turn black, then clogging filt...Show More
mikebteExplorerDec 18, 2015What have seen is the injector having a bad o-ring and oil getting into the return fuel line and turning the fuel dark.I have also seen a cracked head causing Coolant to return to the fuel tank. But that is an extreme situation.
Related ContentInjectorsloosing old membersCummins 6.7 Injector Codes?Toilet broke loose!Ford injector pump failure
