Has any one heard of the Cummins 8.3 ISC having a loose injector causing combustion products to enter the return fuel going back to the main tank and causing the fuel to turn black, then clogging filt...
On my 2003 international 4300 truck, we had a similar problem. Truck was going thru about 3 quarts of oil per hour of run time! Fuel in tank was turning black. Turns out some part in the high pressure fuel system was malfunctioning. Since the oil pressure is used in the fuel pump, oil was crossing over into the fuel return to tank. I forget exactly which part failed.
