Ivylog wrote:
He has been posting about this since 2011. There is not a fuel return line from the injectors on that vintage ISC (2000) so a loose injector would only have compression leaking by it if loose. Cummins has said the only place oil and fuel can mix is in the CAPS injection pump... $$$$. BUT supposedly the excess fuel goes back to the inlet, not back to the tank which turns black. Changing the fuel filters is the cheapest option.
A IH 4300 probably has a IH DT466 engine, not a Cummins.
CAPS are no fun. I have replaced with new CAPS pumps bad out of the box. I strongly recommend you save yourself some time. Have a dealer repair this, if they put on a bad pump they will just put on another until it is running. The CAPS pump is one of them ideas Cummins is just waiting till it dies off.
This does happen, Cummins also said it was ok to use light weight synthetics in the ISX, rather than owning up to this, they just replaced cams in the warranty units until warranty ran out. Next year they switched and now recommend 15W40 conventional.
I had to sit threw a long class while They tried to convince me to tell customers to switch.
