enblethen
Jul 19, 2016Nomad
Low voltage is shutting down the EMS.
You need to check the voltage at the pedestal. Odds are the campground has minimal voltage. Then you and others operate the AC units which causes the voltage to drop below set point in EMS.
Make sure you water heater is running on propane and not 120 volts while AC unit on same phase is running.
