wa8yxm
Jul 20, 2016Explorer III
Dale said it, Your EMS is shutting you down due to low voltage.> Of course when the park electrician comes out it's always good because HE UNPLUGS YOU BEFORE HE READS THE VOLTAGE so there is no load.
ALso your EMS is set to the default (Short) Delay, this is not long enough to let your Air Conditioners recover, You need to re-set it to LONG delay, this means more seconds without power when it happens, but it's easier on your A/Cs.
