CA_Traveler
Jul 20, 2016Explorer III
Your PI unit is working as designed, low voltage on either leg caused both to disconnect.
So far I've only been to one CG with low voltage on a 50A plug. It was very hot with lots of A/Cs running. Also somewhat older CG so that may be a factor. 30A low voltage is much more common.
BTW The only way maintenance can properly check a pedestal is with a monitoring device over time. No doubt they know about the problem and you were stone walled.
