GilONel
Oct 16, 2015Explorer
Loss of 120 volt power in the rv.
Hello Everyone,
I just returned from the Smoky Mts. and had a wonderful time. The RV unfortunately did not.
One of the problems is the loss of 120 volts from the outside source to the rv.
The loss problem is not at the source but inside the RV. No power at all to anything 120 volt related. I tried the breaker at the breaker box but no luck. The manual said that the power coming into the the RV is also controlled by a GFCI plug. Now the only one of those I could see was in the kitchen area. Pushing the reset button on that did not help. I don't believe there are any others. I did look and found none.
I'm just wondering if anyone has any ideas what may be causing this problem, or has had this type of problem. In the meantime I will keep trying to solve it.May end up having to send it in for repair, but that's so expensive.
Thanks
Gil
Thanks
Gil
