rgatijnet1 wrote:
Gazelle05 wrote:
Nope only single pole solenoid. After looking at my salesman cut off switch after I bypassed it there is 5 leads on it. wonder if when bypassing solenoid if that eliminated the power supply? Trying to find new switch to replace old one,nobody stocks and factory has $99. min order. Hope Monaco can help find in the am. Thanks for all the good advise so far. Still have not found my power loss for wash mach. Only one GFI on coach that I can find. It is working. Will pull receptical tomorrow and check if it is ok.
Since it is a plumbing fixture, I would think that your washer should be on a GFI circuit.
Washers are not required to be on a GFCI circuit. AND, the other 120 appliances he mentioned not working would not be on a GFCI circuit(roof AC). If he has partial 12 volt power in the RV, then the Battery Disconnect switch is not the fault. ALL it does is open and close 1 solenoid. It does not control various 12 volt power leads. Just the main 12 volt power to the Coach battery systems. Doug
