dougrainer
Oct 17, 2018Nomad
Wire Man wrote:
Ok, here's my story and I'm sticking to it ??
The tank is under the coach in the middle of the chassis, the fill is in the last right rear compartment (no way to close the valve unless you craw under the coach and do it) so it never gets closed. I did get it working by bleeding off propane from the tank. Not sure why but it start flowing again. All systems go!
Thank y'all again for your help.
You are mistaken on turning the tank OFF. If the tank is under the RV and not easily accessable, they will have an electric solenoid AT the tank. There will be a remote on off electric switch on the pass side in one of the side storage bays/doors. Some of them even have an indicator light with the switch. You need to find and locate that switch for future reference. It is CODE to have a remote shut off system on ASME motorhome LP tanks if mounted underneath where you cannot access the ON/OFF valve handle without crawling underneath. Also, by MOST State LP laws, that valve must be turned OFF when refueling the LP tank. They should then turn it back ON when they are done. Doug
PS, according to your year owners manual, they show the remote fill hose and 80 percent remote hose, but show NO electric valve. If this is true, you have a potentially dangerous set up. What happens if the LP regulator or lines have a major leak? Crawling under the unit is NOT the best way to attempt to turn the valve OFF.
38,766 PostsLatest Activity: Jan 10, 2026
