goufgators
Mar 19, 2016Explorer
Lost keys...
I've lost one set of my keys to the MH. Along with other keys, it has the two keys to the door and an ignition key. I'm not out of business since I have another full set. But, I've got to have a backu...
AstroRig57 wrote:
The OP may have solved his problem, but for future reference you can usually order TriMark keys, by the specific key code, direct from TriMark on their eBay page. I've obtained duplicate sets for both my old and current motorhomes in such a manner.
TriMark Locks Handle Latch RV Motorhome Entrance Baggage Specific Key Code
Also, since I note that the OP has an Itasca, IF you have the original manuals and paperwork that came with your Winnebago product you can find the key codes on a sheet that says "Motor Home Component Information" It can be found in the Winnebago document case with the manuals as well as usually being attached to the back of the "Motor Home Weight Information" sheet that is usually attached in a closet or cupboard.
It lists in this order and format:
Ignition Key Ford xxxxx
Deadbolt Key Trimark xxxxx
Main Door Key Trimark xxxxx
Compartment Door Lock Strattec xxxxx
....followed by the model and serial numbers of virtually every appliance and component originally installed in the RV.
I've made copies of both documents and laminated them, front to back, and keep one on the wall in the wardrobe, one in the document case, and one in a file box at home.
