Gonzo42's avatar
Gonzo42
LOUD squeaky access door.
Access door squeaks quite loudly. As an experiment I crammed a thick wad of newspaper near the latch and that seemed to eliminate the problem.
Now I want to place some foam rubber around the door, maybe in several places. Has anyone advice or experience creating the quiet here?
Where are the best places?
1 Reply
  • May not be the same as yours ?
    But on ours Winnibegao Aspect 28B
    The coach access door squeaked bad, the previous owner tried to put a little piece of foam at the latch, well you have to close the door a little harder now.
    BUT I found the culprit that was causing the most squeak, it was the little rubber stoppers on the screen door rubbing against the door , every bump or turn it would flex and squeak loud.
    I took some rubber seal lube and lubed the rubber stops, cleaned the area where the rubber stops made contact against the door then added a coat of regular automotive wax to the areas where they made contact with the door.
    Problem solved.
