jeremywatco wrote:
Hi all,
Finally took the new Fleetwood Storm to a place with full hookups. I noticed that when hooked up to the city water supply I had really poor water pressure. The spigot seemed to have plenty of pressure, so I am not sure what is up. When running off the water pump I have decent pressure. Any ideas? I dont have the ability to fill the tank from the city water hookup, I have a separate gravity fed tube to accomplish this, so its not a valve there.
And when I say low pressure I mean barley enough to wash your hands under, let alone try to take a shower.
Thanks! Jeremy
Not uncommon. We've seen quite a few low water pressure systems. Especially large RV Parks. Come shower time pressure may go way down.
Weekends and especially holiday weekends the pressure will be so low at come Parks you fill your tank at night and use water from it.
Turn the pump,on as others have said. It will boost the pressure and flow. Don't use those little inline blue filters. They only stop some s Parks with wells sediment and load up really fast, in Midwest. When they load up they bypass the dirty unfiltered water to your faucets.
