inky
Jul 29, 2013Explorer
Low Coolant Sensor
I had a issue with what I thought was a bad low coolant sensor. I replaced it with a new sensor, problem solved. Everything worked great. That was last week and now I have the same issue, the warning light and alarm come for low coolant. I have a 1991 Beaver, Cat 3116 250hp. The coolant sensor is located at the bottom of the surge tank. There is plenty of coolant in the surge tank. When I replaced the sensor before it was clean so I don't think dirt or sludge is a problem. I cleaned the wire connection to the sensor before I put it back together. I did not trace the wire backwards and am wondering if wiring maybe be the problem. That is the project for tomorrow. Any suggestions on what else it could be?
Joe
Joe
