beaubeauExplorerApr 08, 2022Low point drain valves replacementHi. All 3 of these valves are leaking. https://ibb.co/9tky4wT I cut 1 out and bought a SharkBite PEX valve. Apparently the lines look like (to me) PEX, but it’s not quite PEX. The PEX ring...Show More
johntankExplorerApr 09, 2022I don't know what size tubing you have, but it looks looks like you used a 3/8" fitting when you need a 1/2" fitting.
Related ContentReplacement Lights for TTLow Point Drain Valve ReplacementLow point drain valve questionLow point drain valvesReplacement furnace valve? Removing valve?
